Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Common Layer Properties
  1. Blending
    1. Mode
    1. Layer Mask
      1. Mask
        1. LoaderProperty
        2. TextureProperty
        3. a1DGradient
        4. mask
      2. MaskVignette
      3. MaskBorder
  2. Layout
  3. Mapping
  4. Effects
    1. Blending
    2. Mask
    3. MaskSelf
    4. Effect
      1. Effect Group
      2. Color Correction
      3. Filters
      4. Distortion
    5. Layer
Blending
Mode
The Blending Modes control how the pixel values of the current layer are combined with those of the layers rendered before, i.e. the layers which are above the current layer.
Opacity
Blocked
BlockedOnFullTransparency
Layer Mask
Mask
Mask Property uses a texture source as the mask. When adding a mask, a new thumbnail will show the Mask appearance is added to the Layer properties. Right Click on the Mask or click the triangle in the front to bring up the properties for the selected Layer Mask.
In addition, when you hover over a Layer Mask, the two arrows on the right-hand side, pointing up and down, allow for a reordering of the masks if there are more than one. The little X close to these arrows is used to delete each mask individually.
Unfold the Mask Properties and per default the TextureLoader will be shown as well as the Mask Properties.
Loader Property
Loader Property shows a list of internally available images, by default it loads an internal checkerboard image. These images are installed by the Ventuz installer per default, so they are available for all users and projects.
Checker
Checker Blue
Checker Dots
Lines
Noise
Alpha Glow Full
Alpha Glow Half-Full
Alpha Glow
Alpha Glow Half-Sharp
Alpha Glow Sharp
Dimple
Pimple
Liquid
Woodchip
Texture Property
Texture Property adds an external resource like Images, Movies, Streams or a Gradient. The available Texture Properties are Empty (which can be bound to an existing image- or movie node), Movie Clip, Movie Frame, Movie Stream, Live Video, Gradient Texture, Texture Loader or the SVG Loader.
When you select any of these nodes, the nodes will appear in the Content Editor Area. By selecting them, you can change any of the properties for the selected node in the Properties Editor and/or bind their properties.
For a detailed information about the nodes and their properties please read the Texture Video, the Gradient Texture, Texture Loader or the SVG Loader sections.
1D Gradient
Opens the Ventuz Gradient Editor to create a Gradient image that will be used as a Layer mask.
Mask Properties
Mask Vignette
Mask Border
Layout
Offscreen Render Target renders the whole layer to an internal texture which you can access in the Layer - Output Properties. With the Size dropdown menu you can choose if you want to render the layer internally in Full- Half- or Quater- size. For example a 1920x1080px Layer will be 960x540px if you select Half size here. You can also adjust the internal size manually (Manual). Ventuz has some Presets, e.g. 256x256, 512x512, 1024x1024px ..., and so on. As soon as you select any manual size, you can change these values with the Width/Height to suit your needs. Per default the RenderMode is set to Always which renders the Offscreen Render Target in every frame, you can switch to Render Once, so that the Offscreen Render Target is rendered only one time. You can trigger the RenderNow to have the Offscreen Render Target rendered again. The only Option left is the MipMaps which you can disable.
Mapping
Smaller Amount values will divide the other Polar Distortion parameters, meaning that smaller values will interpolate between the original image and the Polar Distortion effect– this is great for animating the Polar Distortion effect as a whole. With the Inverse you toggle to control which coordinate system conversion is applied. If the default Off value is selected the effect will convert from standard Cartesian X,Y to Polar coordinate system, like the "Rect to Polar" setting in other software packages on the market. The Center X/Y values move the center of the Polar Distortion effect calculation. The units are expressed as Percentage of total Image resolution. You can Scale X/Y axis individually and/or Scale All as a whole. The Segments Repeat control a number of segments iterations created. With the Radial Scale you control the result according to the Polar coordinate system with higher values stretching pixel positions in polar directions from the Center location, while smaller values will shrink towards the center location. The Swirl is to deform the Polar Distortion as a spiral, in other words, the higher the values, the more complex the spiral created by the Polar Distortion. Scroll X/Y move the Polar Distortion segments radially in the polar X and Y axis individually. The Perspective setting forces the Polar Distortion effect to try to mimic a fake perspective - it is useful to simulate Tunnel-like effects. If you enabled the Perspective you can use Perspective Adjust and it works like if you would adjust the FOV of the perspective. The Aspect Stretch can be used to apply stretching to the Image. If turned on the Aspect is used to control the Aspect ratio or proportions of the distortion.
Effects
Blending
Mask
Mask Self
Effect
Effect Group
Color Correction
Filters
Distortion
Layer
