The Property Editor lists the input and output "parameters" of the node selected in the Layer Editor, Hierarchy Editor or Content Editor. It also displays the properties of selections in other editors, such as the Animation Editor or Project and Scene Data. Only the properties of Nodes can be bound to other nodes or can be animated. Other properties shown in the Property Editor can only be viewed or edited.
Below the icon, name, and type of the Node, the properties are listed, grouped in categories.
A property is favored to indicate that it is among the ones that are most often used by a typical user. This is visualized by a light gray bar on the left of the name column (in this case only the X/Y properties). The Properties Editor always shows all available properties, the favored tag is just applied to the Quick-Properties Editor available in the Hierarchy Editor on hovering the right bottom of a Node.
By clicking on the small down-arrow the Quick-Properties Editor will come up.
To mark a property as favored, double click on the small, left-most column (not the little box at the very left!). This column is only present when the selection has been done in the Content Editor.
Each row in the Properties Editor represents a single property. In the middle are the two rows for the name of the property and its current value. The value can be changed by double click on the value row or by using the arrows to the right. The bent arrow resets a property to the default value. One can also click and drag the value row to decrease a value by going to the left or increase it by going to the right. The CTRL, ALT and SHIFT modifier keys can be used to slow this down or speed it up, like the following:
| Keys | Effect |
| None | Normal Editing Speed for this Property |
| Ctrl | Normal Speed x0.1 |
| Ctrl + Shift | Normal Speed x0.01 |
| Alt | Normal Speed x10 |
| Alt + Shift | Normal Speed x100 |
During this interactive editing with , a click or pressing Esc will reset the property to the last start value. TAB navigates through all editable properties.
Integer values when entered with a leading 0x or a leading # are interpreted in hexadecimal. Examples: 0xA5=165, #400=1024
Color Values can be changed in several ways and somehow exceed the ways you can change values of other types. You may choose whichever is most comfortable. By clicking the downwards arrow of the Value Column a small window opens, where you can edit the current property.
On the top, you can change the current Hue of the color with the help of the Color Circle on the left. Moreover you can control its Saturation and Lightness with the Color Square on the right. Below you see the RGBA values which you can change to any other integer value in the Property Editor. Next to it, there is the representation in HSL which works the same.
On the right, the Color Preview shows two colors defined as a square with an inner and outer area. The color in the outer area is the formerly picked color whereas the inner square shows you a preview of the currently picked color. You can drag and drop both squares to the bottom of the window and add them to the Color Presets collection. The Color Presets shows the most recent colors picked, they can be overwritten or deleted by dragging them into the bin.
Whenever you change one of the representations, not only the Renderer updates the Color and already takes notice of that but also all other representations inside this window will update their values.
The last way to change a color is the Color Picker. You can activate the Color Snoop mode by clicking and dragging the colored rectangle on the left of the Value Column. Now you see the Color Picker (see above image) instead of your cursor. With that, you can read out any Pixel rendered on your Monitor.
The most left rectangle is filled with the currently snooped color. The Square in the middle works as a magnifier of the snooped area (top left square) and shows you a better representation of the space around your cursor. On the right you see the RGB values - one column uses the interval 0-255 and the other as Hexadecimal numbers. When
By using the Arrow Keys while snooping you can pan the cursor pixel-wise.
Gradients are similar to Color Values, though they can define a gradual change between two or even more color values and based on these create a texture. You can choose one of some presets by clicking on the downwards arrow in the value column.
Click on the dots to the right of it to open the Gradient Editor. It looks similar to the Color Editor but has an additional Gradient on top of the Window. Here you can define Keys for both Color (bottom) and Alpha (top). To create a Key click directly below or above the Gradient respectively. You can move the Keys around by either dragging them near the Gradient or by changing its p-Value (position). Click on a Key to select and edit it. By dragging a Key away from the Gradient you can delete it.
Changing a Color Key's Value works the same as described above. Changing an Alpha Value works very similar, but you can only define the Lightness - 0 means no opacity and 255 means fully opaque. By checking the Alpha-Flag the Gradient only outputs an Alpha Channel and therefore only Alpha Keys are being shown. The Color Picker feature is also available by clicking on the
-Icon on the top left.
Instead of manually setting a property to a specific value, it can be bound to the Output Property of another node. Click and drag the name row entry of the property to another node in the Layer Editor, Hierarchy Editor or Content Editor. When releasing , a list of compatible output properties will appear if multiple compatible output properties exist; otherwise the binding will be established immediately.
Instead of binding a property, it can also be animated by a Keyframe Animation. To animate a property, either drag it to the Animation Editor or press CTRL while clicking on the property name. For more information on animation, see Animation and State Engine.
Similar to the animated binding, properties can be added to Project, Scene and Animation Data by either draging them to the desired editor, using the context menu entries or the shortcuts CTRL SHIFT and clicking to add a property to Animation Data and CTRL ALT SHIFT and clicking to add a property to Scene Data.
Most properties represent values that influence or are generated by a node. A number of nodes also generate or listen to events that fire when a certain situation arises. The following screenshot of the Touch Button node shows both input and output properties and events.
The red square next to the Reset property can be clicked to fire the Reset event, in this case causing the button to reset to its internal state. The output events on the other hand fire when a certain situation occurs, for example, the SingleTap event is fired when the user presses and releases the button within a short timeframe. Apart from triggering the action, the button is intended for, this could, for example, also be used to animate the color when the button is pressed to give the user a visual feedback.
The small square on the left indicates the exposure state of the property. By double-clicking on it, the user can assign a name, category and the default value of how the property should appear on the parent container level.
To expose a property, click on the name of the property in the Property Editor and choose Expose/Edit... from the appearing context menu. The name and category of the property, as it appears on the Layer or Container, can either be kept the same as on the original node or be reassigned in the dialog that opens. Press OK and the square to the left of the property name will change to green, symbolizing that this is now an exposed property. Note that exposed property names have to be unique within a container. Exposing two properties with the same name will not only confuse other Ventuz operators but can also disrupt the binding logic.
To quickly expose a property without changing its name or category, click the small square to the left of the property. To quickly hide a property, click on the square. A double-click will bring up the Expose dialog.
If one wants to navigate the node that exposes its properties to the higher container level, a long click on the interesting property will display a context menu. Not all menu entries are enabled. This depends on the exposing level and the binding state of the selected property. For the navigation in an Exposing hierarchy the menu entries to Origin and to Origin Root are useful. to Origin navigates inside a container to the node that exposes the selected property. This can be any of the Ventuz nodes. to Origin Root navigates to the root of an exposing chain over multiple container nodes. In this case, the destination node can be any of the Ventuz nodes except the container nodes.
If an input property is bound, the menu entry to Source Node will navigate to the node which is bound to the selected property. The navigation to Property is only possible if the Favored option is enabled. In this case, a Hierarchy node inherits the favored input properties of all bound nodes for display in the Property Editor. Selecting to Property on such an inherited property will navigate to the real owner of this property.
Some Nodes like OSC Input Node or the Script Nodes can have a user-defined number of Properties. The ability to add or remove properties is called a Custom Model. It is usually accessed by a button at the bottom of the Property Editor.
In some of the above screenshots, one of the boxes containing the name or value of a property has a different color than the rest:
