Auto-routing between states
A Template is an entity that describes both a logical and visual part that can be activated in conjunction with its corresponding data population. Every scene automatically defines a Scene Template, which represents the scene without any dynamic data defined for it. All other templates in the scene are defined by Present States of an animation logic and are usually associated with some amount of dynamic data. All Templates defined by a scene are organized in a hierarchical order that also declares their relationship between each other (Concurrency, Dependency, Independency). Templates are always organized in so called Template Hosts. Template hosts are organized in a host-tree where each host has exactly one parent host (except the root) and has one or multiple sub-hosts.
Relationships
If the template engine is used Scene-comprehensively, it defines the root of the host-tree. For every scene that is injected into the project template host one Template is defined. So all scenes managed by this host are concurrent: there's none or one scene active at a time.
Animation1 Group2_Animation2 Group2_Animation3
| Name | C# Type | Modes | Description | Attributes |
| Animation | - | - | The Animation item defines a field that addresses a possible sub-template. The actual value of this field is null or a data instance (TemplateData) of a sub-template. | Required |
| Trigger | - | RW | A Trigger can be either an asynchronous event sent out to the remote client (R), a trigger sent from the remote client to Ventuz (W) or both (RW). | |
| Group | - | (RW) | A Group contains multiple sub-DataItems and acts like a folder. The mode is the sum of all sub-items only defines if the items below are readable and/or writable. The group itself has no value. | |
| Float | float | RW | A floating point value | Default, Min, Max, Speed |
| Integer | int | RW | An integer value | Default, Min, Max, Speed |
| Boolean | bool | RW | A boolean value | Default |
| String | string | RW | A string value | Default, MaxLines, MinLines |
| Enum | string | RW | A string value of type that matches the values of an enumeration. The possible values are define in the field Elements. | Default, Elements |
| Color | Color | RW | A color value | Default, Alpha |
| Asset | Uri | RW | A general Uri value that addresses one or multiple asset pools | AssetPools |
| FloatArray | float[] | RW | An array of float values | Default, MinLength, MaxLength |
| IntegerArray | float[] | RW | An array of integer values | Default, MinLength, MaxLength |
| BooleanArray | bool[] | RW | An array of boolean values | Default, MinLength, MaxLength |
| ByteArray | byte[] | RW | An array of byte values | Default, MinLength, MaxLength |
| StringArray | string[] | RW | An array of string values | Default, MinLength, MaxLength |
| Name | C# Type | Description |
| Name | string | Defines the technical name of the DataItem |
| Label | string | Contains the label text how the DataItem should be presented to the user |
| Description | string | Contains a short description of the DataItem |
| Required | bool | Defines if a sub-template must be assigned (true) or not (false) |
| Choices | string[] | Optional predefined choices for that string |
| Default | item type | Default value of the DataItem |
| Format | string | Specifies a format string for automatically created template data description |
| Min/Max | item type | Minimum and maximum value of the DataItem |
| RegEx | string | If specified, the string must match this regular expression |
| Speed | item type | Edit speed of the DataItem |
| Min/MaxLines | uint | Minimum and maximum number of text lines for the DataItem |
| Elements | string[] | List of valid elements to fill the DataItem |
| Alpha | bool | True if the color requires the alpha component |
| AssetPools | AssetPool | Asset pools of the DataItem |
| Min/MaxLength | uint | Minimum and maximum number of elements in the array |
| UserData | string | A user-defined general purpose string |
ventuz://templates
ventuz://templates/
ventuz://templates/<sceneidentity>/Examples:
ventuz://templates/scene1/ ventuz://templates/scene2/ ventuz://templates/folder|scene3/
Please note that the Project Template Host does not have a name! Therefore the first path segment after the base uri is always the name of the Scene Template Host regardless if the scene host is parented in a project host or not!
Two scenes saved as .\Scenes\Folder\Scene1.vzs and .\Scenes\Folder_Scene1.vzs would result in an identical Uri address for their template hosts: ventuz://templates/folder_scene3/. Injecting these two scenes into a project template host will cause an error to be thrown!
ventuz://templates/<sceneidentity>/<AnimationDataItem>/ ventuz://templates/<sceneidentity>/<AnimationDataItem>/<AnimationDataItem>/.../Examples:
ventuz://templates/scene1/Animation1/ ventuz://templates/scene1/DataGroup.Animation.DataItem/ ventuz://templates/folder|scene3/DataGroup.Animation.DataItem/ ventuz://templates/folder|scene3/DataGroup.Animation.DataItem/DataGroup.DataItem/
Two Animations bound to a DataModel as /DataGroup/Animation1 /DataGroup_Animation1 would result in an identical name for their sub template hosts: ventuz://templates/scene1/DataGroup_Animation1/. The Scene Model Validator will cause an error to be thrown!
ventuz://templates/<scene_identity>/Scene ventuz://templates/<scene_identity>/<Animation_DataItem>/<TemplateName>Examples:
ventuz://templates/scene1/Animation1/Template1 ventuz://templates/scene1/Animation1/Template2 ventuz://templates/scene1/Animation1/Animation2/Template3
The Scene Template has always the reserved name "Scene". This name cannot be changed by the user. Other Scene template may be added in the future (Global, Constant, etc
All templates defined in a template host must be unique. If multiple Animation Nodes are grouped all Present States must have a unique name across all animations within that group. Otherwise an error will be thrown.
".group.group.item"
"$DataModelname.group.group.item"
"TemplateName.group.group.item"
Examples:
.Text1 Animation1/Template1.Line1.Text Animation1/Template1.Line1.Color Animation1/Animation2/$Group2.Headline.Text
In order to store and transfer a complete set of data, we plan to integrate multiple different data formats for being compatible to different platforms and integrators:
Ventuz supports three different data formats: XML, JSON and BIN. all of these formats are 100% compatible to each other and the user can decide which format he wants to use. All three formats are text based and the receiver (Ventuz) can easily decide which parser to user. It simply looks to the first non-whitespace character: "<" for XML, "{" for JSON and any other for base64-BIN
The JavaScript Object Notation (JSON.org) has some advantages and disadvantages compared to XML:
<VTD ns="ventuz://templates/ingame/Scene">
<LowerThird_Center ns="ventuz://templates/ingame/LowerThird_Center/NS2LAdd">
<FirstLine>First Line</FirstLine>
<FirstAdd>Addon Text</FirstAdd>
<SecondLine>Second Line</SecondLine>
<Visual01>ventuz://scenes/Assets/logos/FrankfurtSnakes.vzs</Visual01>
<Visual02>ventuz://images/Assets/sponsorlogos/HH.png</Visual02>
</LowerThird_Center>
<UpperThird ns="ventuz://templates/ingame/UpperThird/Scoreboard">
<Banner ns="ventuz://templates/ingame/UpperThird/Scoreboard_Banner/Banner2LAdd">
<FistLine>First Line</FistLine>
<Visual>ventuz://scenes/Assets/logos/HP.vzs</Visual>
</Banner>
</UpperThird>
</VTD>
"@": "ventuz://templates/ingame/Scene",
"LowerThird_Center": {
"@": "ventuz://templates/ingame/LowerThird_Center/NS2LAdd",
"FirstLine": "First Line",
"FirstAdd": "Addon Text",
"SecondLine": "Second Line",
"Visual01": "ventuz://scenes/Assets/logos/FrankfurtSnakes.vzs",
"Visual02": "ventuz://images/Assets/sponsorlogos/HH.png"
"UpperThird": {
"@": "ventuz://templates/ingame/UpperThird/Scoreboard",
"Banner": {
"@": "ventuz://templates/ingame/UpperThird/Scoreboard_Banner/Banner2LAdd",
"FistLine": "First Line",
"Visual": "ventuz://scenes/Assets/logos/HP.vzs"
VlREMSAfdmVudHV6Oi8vdGVtcGxhdGVzL2luZ2FtZS9TY2VuZaARTG93ZXJUaGly ZF9DZW50ZXIgM3ZlbnR1ejovL3RlbXBsYXRlcy9pbmdhbWUvTG93ZXJUaGlyZF9D ZW50ZXIvTlMyTEFkZGEKRmlyc3QgTGluZQlGaXJzdExpbmVhCkFkZG9uIFRleHQI Rmlyc3RBZGRhC1NlY29uZCBMaW5lClNlY29uZExpbmVhMHZlbnR1ejovL3NjZW5l cy9Bc3NldHMvbG9nb3MvRnJhbmtmdXJ0U25ha2VzLnZ6cwhWaXN1YWwwMWEqdmVu dHV6Oi8vaW1hZ2VzL0Fzc2V0cy9zcG9uc29ybG9nb3MvSEgucG5nCFZpc3VhbDAy /6AKVXBwZXJUaGlyZCAvdmVudHV6Oi8vdGVtcGxhdGVzL2luZ2FtZS9VcHBlclRo aXJkL1Njb3JlYm9hcmSgBkJhbm5lciBCdmVudHV6Oi8vdGVtcGxhdGVzL2luZ2Ft ZS9VcHBlclRoaXJkL1Njb3JlYm9hcmRfQmFubmVyL0Jhbm5lcjJMQWRkYQpGaXJz dCBMaW5lCEZpc3RMaW5lYQpBZGRvbiBUZXh0CEZpcnN0QWRkYQtTZWNvbmQgTGlu ZQpTZWNvbmRMaW5lYSN2ZW50dXo6Ly9zY2VuZXMvQXNzZXRzL2xvZ29zL0hQLnZ6 cwZWaXN1YWz/////
