Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Matrix
  1. Matrix Operation
  2. Vector Transform
Rotation XYZ This node provides a matrix to rotate around the X, Y or Z axis.
Scaling This node provides a matrix to scale along the X, Y and Z axis.
Translation This node provides a matrix to translate along the X, Y and Z axis.
The Matrix Nodes provide special types of matrices that can be used as Input Properties for the World Transformation or View and Projection of the Camera.
Matrix Operation
Vector Transform
  • Axis nodes
  • Script nodes
