Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Web Browser
  1. Usage and Interaction
  2. Input
    1. Multitouch ´
    2. Mouse
  3. Browser Functionality
    1. Browser Cache
  4. Progress and Status
    1. Content
    2. Cursor
  5. JavaScript
    1. Methods/Events
    2. Properties
    3. Execute On Load
    4. Transparent Background
  6. Limitations
The Web Browser node renders web pages into a texture so their content can be used inside a Ventuz scene. Since Ventuz 5.3 this is done based on the ​Chromium Embedded Framework CEF.
Input
Multitouch ´
​Chromium Embedded Framework CEF can handle maximum 16 inputs per browser.
Mouse
Code Description
13 Return
9 Tab
8 Backspace
127 Delete
27 Escape
The unicode values for the most commonly used characters can be found ​here and ​here. Additional information on other character sets can be found ​here.
  • Load: Load the URL/HTML specified in the NavigationURL or NavigationHTML respectively.
  • Reload: Reloads the current content (same as pressing F5/Refresh in a dedicated browser application).
  • Stop: Stops/interrupt the current loading process.
  • Forward: Go one page forward in the navigation history.
  • Backward: Go page backward in the navigation history.
Browser Cache
%HOMEDRIVE%\ProgramData\Ventuz5\WebCache
Progress and Status
Content
  • CurrentURL: The URL of the currently displayed HTML page.
  • TargetURL: If the cursor hovers over a link, this provides the URL the link leads to.
  • Title: The title of the currently displayed HTML page.
  • Tooltip: If the content contains a tooltip for the current position of the cursor, it will be provided in this property.
Cursor
0 Pointer (default)
1 Cross 2 Hand 3 Ibeam 4 Wait
41 Custom
JavaScript
The Web Browser node supports the ​JavaScript scripting language both as part of the content as well as a means of interaction between Ventuz and the site content. This is done by defining input/output properties, methods and events in the Custom Model editor at the bottom of the Property Editor.
Methods/Events
<html>
<head>
<title>Method Test</title>
</head>
<body>
function CalculateSquare(value) {
  var result = value * value;
  document.write("The square of " + value + " is " + result + "<br>");
  ventuz.Result(result);
</script>
</body>
</html>
Properties
Ventuz properties can also be connected to the script code via the Custom Model. They become available as members of the global ventuz object. Changes in the input properties are automatically reflected in the script code but updating outputs have to be explicitly triggered inside the script code by calling the function ventuz.updateOutputs().
<html>
<head>
</head>
<body>
function CalculateSquare() {
  ventuz.result = ventuz.value * ventuz.value;
  document.write("The square of " + ventuz.value + " is " + ventuz.result+ "<br>");
  ventuz.updateOutputs();
</script>
</body>
</html>
Execute On Load
The property WebBrowserJavaScript can optionally contain a ​JavaScript snippet that is injected and executed on every loaded page. This opens many possibilities to operate on external pages.
Example 1:
Example 2:
Creates two methods called UP and DW in the Custom Model to invoke the defined JS functions. The displayed window will scroll up/down when Ventuz invokes these methods. (See also function ​scrollBy())
Disable PluginPlugins (like Adobe Flash) are disabled.
Allow ClearTypeDisables/enables ​Clear Type. Monochrome scaled text with Clear Type enabled result in colorful edges.
Allow ventuz:// from external sitesAllows you to reference assets inside a Ventuz Project
Ignore SSL certification errorsExecution of Java Script code is disabled.
AudioAllows you to configure the In and Out Ventuz Ordinals and global browser Volume. Also check the crosspoint section in the Audio Video Config for further information.
User AgentSome web sites (like Facebook.com) expect special keys in the user-agent string. The user agent string can be manually adjusted here. See ​http://www.user-agents.org
Limitations
  • The maximum resolution of the web browser is 4096 x 4096 pixel.
  • A touch is immediately claimed by the Web Browser, so a combination of Touch Translation node with the Web Browser node is not possible.
  • User login prompts and other popup windows are not supported.
  • Multi Touch
  • Ventuz Input Subsystem
  • ​JavaScript
