Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
3D Touch Simulator
3D Touch Simulator Simulates a 3D Touch device to interact with Interaction Nodes.
Using the Touch Simulator
By default the Id is set to 10. This is to prevent conflicts with VR-Controllers, since these real controllers already have Id's assigned.
Properties
Touch Methods
Touch Method Behavior
  • Virtual Reality How To
  • How To Cluster Render
  • Interaction Nodes Overview
