Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Video Source Selector
Video Source Selector This node allows to select different available sources and activate them.
Most of the Input devices do not provide any selectable sources. ​Newtek NDI streams are one of the main use cases.
  • ​Newtek NDI
  • How to use NDI
  • Configured Input Devices
