Ventuz 5 Quick Guide
Ventuz 5 Designer
Ventuz 5 Node Reference
  • Point Options
  • Render Options
  • FFT Audio Analysis
Ventuz 5 Director
  • PropertyGroups
Layer Editor Shortcuts
View
 drag Scroll vertically
 wheel Scroll vertically
Selection
click  Node Select Node
SHIFT click  Node Add Node to selection
CTRL + Q Node Select Siblings
Visibility
CTRL + R Node Toggle Render Point (solo Layer)
ALT + Node Toggle Render Point (solo Layer)
CTRL + SHIFT + R selected Nodes Lock Visibility
Editing
CTRL + B selected Nodes Block selection (disable Eye)
click  Node Expand/Collapse children
CTRL + L selected Nodes Expand/Collapse selection
CTRL + D Node Navigate one level down to edit selected Layer
ENTER Node Navigate one level down to edit selected Layer
click  Node Navigate one level down to edit selected Layer
CTRL + U selected Nodes Navigate up to layer level
Naming
double  Node Edit name
F2 selected Node Edit name
Drag&Drop
Drag&Drop Layer Nodes inside the Layer Editor or from Repositories or Toolbox
drop Drop-Target (orange line) Copy/Move
SHIFT drop Drop-Target (orange line) Move
CTRL drop Drop-Target (orange line) Copy
CTRL + ALT drop Drop-Target (orange line) Reference Copy
Drag&Drop Properties or Methods
hover Node, Property Group or Category Un-collapse Layer, Group or Category
  • Shortcuts: Content Editor
