Camera Navigation
  1. Free Flight Camera
  2. Walk Through Camera
  3. Orbit Camera
  4. Create a Camera from a Free Flight Camera
You can move the camera with Keyboard-shortcuts and Mouse, when the In-Render-Edit Mode is active. As soon as any of the cameras is active, you can see a Camera Info Panel in the bottom of the Render Window.
Free Flight Camera
To navigate the Free Flight Camera, hold the right mouse button  hold and use W,A,S,D to move the camera around.
If you just hold the right mouse button  drag and move the mouse around, you would Pan & Tilt the camera, like rotating your head. (The camera info panel will say: FLY)
Walk Through Camera
You can also increase/decrease the speed of movement for the Free Flight- and Walk Through Camera by holding the  hold and scroll the  scroll. You can see the Speed value in the camera info panel change. Hold Shift or Ctrl to increase/decrease the Fly-/Walk speed for a moment.
Orbit Camera
To make use of the Orbit Camera you must have an object selected. Hold ALT &  drag, left mouse and move the mouse around. (The camera info panel will say: ORBIT)
You can use any of the above described cameras to create a camera in in the Hierarchy! Just fly to your desired position, adjust your camera in Free Flight Mode and press Ctrl +  INSERT. A new camera will be create inside the active 3D layer.
  • Render Point/ Isolate Mode
