Two nodes are connected by a line if at least one property of one is bound to a property of the other. The binding relationship can be bidirectional in which case both ends of the line have an arrow head. To remove a binding, click on the line and a list of all bound properties opens. By selecting one of the entries, the respective binding will be removed. To remove all bindings of a node, select the node and press SHIFT + DEL or select Unbind from the Edit Menu.
Sometimes you want to add a node in between an existing connection between two nodes. To do so you can just grab a node from the Toolbox and drop it on a Binding if there is only one connection that fit the value type the node is inserted otherwise you get a list of available possibilities.
Copy
Content Nodes can be copied by simple CTRL + C, CTRL + V. To copy a single content node without the bound content select the node with CTRL. CTRL + P will duplicate the node and place the copy next to the original one. CTRL + SHIFT + P duplicates the node and creates binding to the existing source nodes.
Zoom
Since the number of content nodes in a scene can get quite large, the Content Editor only visualizes a part of the network. By moving the mouse wheel, the user can zoom in or out of the network. Pan the Content Editor by pressing
The position of the individual nodes can be arranged by the user by clicking and dragging nodes. Each node can be assigned a name by double-clicking on the node name or pressing F2. As with the Hierarchy Editor, parts of the network can be collapsed by clicking on a node. To reach the Context menu, press and hold for a few seconds.
Nodes displayed in the Content Editor can be grouped into Content Families to assure the relative positioning of the nodes in such a Family and to visualize a functional relationship. Select some nodes with the rectangular selection or by clicking on nodes with a pressed SHIFT. Pressing CTRL + SHIFT + F will create a Content Family for the nodes and visualize this with a gray rectangle around them in the Content Editor.
Content nodes can be drawn in a Small version to save space in the Content Editor. Just press CTRL + T to toggle the size of a Content node.
