Filter effects change the outcome of the image in a more general way. Instead of just moving pixels or simply changing a color value, they oftentimes change pixels according to other pixels on the screen using specific rules. This page gives you an overview of what is possible with these effects.
A Drop Shadow effect that generates a 2D shadow effect based on the Layer Alpha. It uses the same computation internally as the Blur effect and the Shadow can be tinted into colors other than Black. Apart from pure drop shadows, the effect can be used for many other effects, such as to create object glow effects (with light color settings) or outline effects (with a very small diameter setting). It features these parameters:
The available values are “In Percent” -the default one, using percentage of the whole image size, or “In Pixels” – using absolute pixel values.
Delay by a couple of frames.
