Color
Color This node changes the objects' base color without affecting the lighting model.
Solid Color This node sets the object color without any lighting influence. This results in a flat, light independent shading.
The Solid Color and Color Nodes are Aliases of the Material Node. See the Lighting Models section of the Material Node's documentation for more details.
The Solid Color Alias is using a NoLight Lighting Model. This is usually used if any form of lighting or shading is undesirable for an object. By changing the LightingModel Property Group to e.g. a Phong Lighting Model you can change your Color Node to a Material Node with shading and vice versa.
If a quick change of the base color is desired but the Lighting Model should just be inherited from the Hierarchy you can use the Color Alias instead.
Material User Interface
Generally these tabs exist:
Standard
Alpha Options
Lighting Model
Material Stages
Shadow Options
Shadow Options
Drawing Style
Draw Mode
Blending
Color Write
Alpha Blending
Testing
Alpha Testing
ZBuffer
Icon and Decoration
Rendered Preview
Dedicated Option Icon
Extraction
Material Definition
Material Options
  • Alpha node
  • Material node
  • Color Converters
