Mesh Loader
For a discussion on importing non-vzm files (i.e. OBJ, COLLADA, ...) see Importing of 3D Geometry and for a list of supported geometry formats and their characteristics go to Supported Formats.
Improve Transparency
When using alpha blending on concave meshes the interior of the object becomes visible, which is often undesirable.
Enabling the ImproveTransparency property can solve this problem in many cases. This is done by rendering the object twice, first only in the depth buffer and then normally. So this is a bit more expensive. When alpha is at 100% doing this is not necessary and therefore skipped, so you only have to sacrifice performance when it matters.
  • Importing of 3D Geometry
