The performance statistics is a display rendered above the Ventuz output. It can be enabled from the designer or the live options to analyze performance problems in a scene. This has been enhanced as of Ventuz 4.04.00.
The performance statistics contain a lot of information. In many cases displaying it all can be a bit overwhelming and requires a lot of screen real-estate. So individual sections can be enabled and disabled and with the Frame Count the amount of visible frames can be adjusted:
With all sections enabled, it can look like this:
In general:
Creation Calls are an exceptionally expensive part of the DirectX API and should only happen during scene loading.
Persistent Resources are resources that accumulate and are never deleted until Ventuz is quit. VertexFormats and VertexConverters are cheap internal resources that should stay below 25. Shaders is the number of different shaders that have been used since Ventuz started.
GPU Memory: this shows how GPU memory is divided into geometry (vertex and index buffers), textures and Color/Depth Target (textures used as rendertarget or depth buffer).
The states mean:
The states are:
The buffers show how many buffers Ventuz has allocated and how many frames in the future are available. If these buffers run dry, increase the number of buffers for that movie. At the end of each line you can see the exact Cluster Clock when each Movie Started. Like the lead this is mainly useful to check syncronization of movies in a cluster.
Each line represents:
public static Ventuz.Kernel.Tools.PerfMon.Token Script1 = new Ventuz.Kernel.Tools.PerfMon.Token("Script1", 0xff8000);
using(Script1.MeasureCpu) { System.Threading.Thread.Sleep(3); }
Here is a complete example:
using System; using Ventuz.Kernel; using Ventuz.Kernel.Tools; public class Script : ScriptBase, System.IDisposable { private bool changed; public Script() { } public virtual void Dispose() { } // Token for Performance Timing public static PerfMon.Token Script1 = new PerfMon.Token("Script1", 0xff8000); public override void Validate() { changed = true; // Logging that will be overwritten every frame PerfMon.PrintFrame("Hello World\n"); // Logging that will spam the console PerfMon.PrintConsole("LogLogLog\n"); // wait a few milliseconds, and add a bar to timing using(Script1.MeasureCpu) { System.Threading.Thread.Sleep(3); } } public bool OnEnable(int arg) { Ventuz.Kernel.Tools.PerfMon.ConsoleLogEnabled = true; Ventuz.Kernel.Tools.PerfMon.FrameLogEnabled = true; return false; } public bool OnDisable(int arg) { Ventuz.Kernel.Tools.PerfMon.ConsoleLogEnabled = false; Ventuz.Kernel.Tools.PerfMon.FrameLogEnabled = false; return false; } public override bool Generate() { if (changed) { changed = false; return true; } return false; } }
So for shortest delays:
Red(ish): Validation
Green(ish): Rendering
Blue(ish): Idle
Yellow(ish): Postprocessing
Video Process:
Other
