Renderer Window
  1. In Render Edit Mode Manipulation
  2. Camera Navigation in Renderer View
    1. Walk Through Camera
    2. Orbit Camera
    3. Create a Camera from a Free Flight Camera
  3. Render Point and Isolate Mode
    1. Isolate a Layer
    2. Camera Shortcuts
  4. List of Shortcuts for Camera Navigation
Ventuz is a realtime WYSIWYG design application. The Renderer Window shows the rendering result of the Scene/Presentation and updates it every frame. Additionally some information can be displayed as overlay graphics like Performance Statistics or Transformation Gizmos for the in-renderer editing.
On the top right of the Ventuz Designer User Interface there is a row of buttons. A short hint to their functionality can be found in the list below.
Pixel Snoop This Tool picks the color of a certain pixel and copies the information to the clipboard, see PixelSnoop
Wireframe Turns the Wireframe-mode on and off
Statistics Shows / hides the Statistics for the current scene, like CPU Usage
Input Diagnostics Turns on the Input Diagnostics
Bounding Boxes Shows / hides the bounding boxes
Show Key Toggles the render output to show the Key signal
Fullscreen When activated the render window will be shown in full screen
In-Render Edit Mode As long as In-Render Edit Mode is activated, objects can be moved, rotated and scaled inside the render window
Show non-render objects All objects in the scene will be rendered including hidden objects like lights and cameras
Object-aligned/ Property aligned Toggles the orientation of the Transformation Gizmo in the renderer
Translate Switch to translation mode. In-Render Edit Mode has to be activated
Rotate Switch to rotation mode. In-Render Edit Mode has to be activated
Scale Switch to scale mode. In-Render Edit Mode has to be activated
Snapshot to File Takes a screenshot and saves it to disk
Snapshot to Clipboard Takes a screenshot and copies it to the clipboard
Render to Disk Opens the Render To Disk Tool
All rendering options are also available as Live Options in the Configuration Editor.
To change between Window and Fullscreen mode press Alt +  Enter.
To switch into the In-Render-Edit Mode press TAB.
If the In-Renderer Editing is enabled, it is possible to select/move/rotate/scale objects directly in the Renderer window by clicking and dragging the corresponding object handles. Note that in this mode the scene logic does not receive any Mouse and Keyboard events!
When you scale, move or rotate an object with the Transformation Gizmo, Ventuz will apply these changes to the next axis in front of that object, but only if that axis has only one Object as its child. If there is no such axis or if there is no axis existent at all, Ventuz will place one in front of the transformed Object.
When clicking in the rendered image Ventuz performs a raycast and selects the first hit object in 3D Space and jumps to the corresponding Node in the Hierarchy Editor.
You can move the camera with Keyboard-shortcuts and Mouse, when the In-Render-Edit Mode is active. As soon as any of the cameras is active, you can see a Camera Info Panel in the bottom of the Render Window.
To navigate the Free Flight Camera, hold the right mouse button  hold and use W,A,S,D to move the camera around.
If you just hold the right mouse button  drag and move the mouse around, you would Pan & Tilt the camera, like rotating your head. (The camera info panel will say: FLY)
Walk Through Camera
You can also increase/decrease the speed of movement for the Free Flight- and Walk Through Camera by holding the  hold and scroll the  scroll. You can see the Speed value in the camera info panel change. Hold Shift or Ctrl to increase/decrease the Fly-/Walk speed for a moment.
Orbit Camera
To make use of the Orbit Camera you must have an object selected. Hold ALT &  drag, left mouse and move the mouse around. (The camera info panel will say: ORBIT)
You can use any of the above described cameras to create a camera in in the Hierarchy! Just fly to your desired position, adjust your camera in Free Flight Mode and press Ctrl +  INSERT. A new camera will be create inside the active 3D layer.
The isolate Mode is basically the Render Point functionality. Doubleclick  doubleclick any object in the Render Window. This will set a Render Point for the selected Object, all other parts of the scene tree are ignored. The navigation and shortcuts are listed below. Doubleclick  doubleclick the selected object again to leave the Isolate Mode
Selecting a node and pressing CTRL + R will set the Render Point to that Node. Additionally you can activate the Render Point in the Hierarchy/- Toolbar or select the Set Render Point from the context menu with a  click on the selected Node. The Render Point defines teh isolated subtree in the Hierarchy. For the following screenshot it means the V_Mesh02 is isolated and centered in your Rendering Window.
Isolate a Layer
To isolate a Layer from its composition select it and press CTRL + R. You can also press the Isolate button on the Layer Tool Bar. It allows you to view and edit the Layer outside the context of your already finished composition without changing the actual surrounded logic.
Camera Shortcuts
Move the camera:
 drag Rotate object
ALT +  drag Orbit around object
 drag Rotate camera
Ctrl + ALT + drag Roll camera
ALT +  drag Pan camera
ALT +  drag Zoom camera
 doubleclick Leave Isolation Mode / Remove Render Point
Following is a list of all Shortcuts:
Tab Toggle In-Renderer Editing
R Switch to Rotation Mode
T Switch to Translation Mode
L Switch to Scaling Mode
 drag rotate camera (rotate head)
 hold + W,A,S,D Move/Walk around - Free Flight Cam (if heightlock enabled: Walk Through Cam) (Shift & Ctrl faster/slower *10)
 hold + E,C Fly up/down (increase/decrease height)
Num * Toggle height lock
 hold +  scroll change movement speed (Fly-/Walk- cam only)
Alt +  drag Rotate Camera (around targeted point (Orbit Camera))
Alt +  drag Zoom/FOV Camera (toward targeted point)
Alt +  drag Pan camera (move targeted point)
Ctrl +  Alt +  drag Roll camera
Num1 Front View
Num3 Side View
Num7 Top View
Num2 and Num8 Rotate around x-Axis (Turn Up/Down)
Num4 and Num6 Rotate around y-Axis (Turn Left/Right)
Num , Focus on selected Object (only with selection)
Num5 Toggle Orthographic / FOV (only with selection)
Num0 Toggle Free Flight Cam / Active Cam
Num9 Reset Roll
Num Enter Reset Free Flight Cam
Num / Toggle On Screen Camera Help
Ctrl +  insert Create a camera of the actual Free Flight Camera
Hold Ctrl +  Shift Pixel Zoom
  • Axis Node
  • Camera Node
  • Render Point and Isolate Mode
  • OffScreen Rendertarget Layer
